1993 Mazda MPV Unstarted 3 Years
CJJRTWO
i have a mazda mpv 1993. i havent started it in 3 years. will i have any problems with it if i decide to put it back on the road.
Mar 17, 2007 at 4:17 AM
  • 75,988 POSTS
Tackle all the basics-pull the plugs and clean it
Mar 20, 2007 at 1:24 PM
HELLCAT18
  • 21 POSTS
First thing, pull your air-cleaner cover and check for rodent presents past the air filter. If their are, don't start it cause you'll kill it. If there aren't, then change the oil, change all the filters, drain the old gas, and dump a bottle of Gas line anti-freeze into the tank when you put more in(gas line anti-freeze is basically alcohol and will help de-gum the lines and such) Make sure that you have a friend who is good with cars look it over before you start it to make sure that you covered all your bases, then fire it up!
Mar 29, 2007 at 11:19 PM
SERVICE WRITER
  • 9,123 POSTS
Chance are good you will have problems. Some will be immediate and some will be on going as you drive it. Expect brake work, potential brake lines or fuel lines. Anything that is rubber, such as hoses, belts, vacuum lines present questions from dry rot. Anything that is moveable may be seized of very stiff.
I would be inclined to expect this to be a problem child from the similiar long setting cars I have seen.
Before attempting cranking it, shoot some oil or penetrating fluid into the cylinders and turn the engine over by hand to make sure the cylinders move okay.
Mar 30, 2007 at 11:19 AM
Suggested Repair
Before starting, inspect the air cleaner for rodent debris and do not start the engine if any is present. Change the oil and filters, drain the old fuel, and add fresh fuel with gas-line antifreeze. Check brakes, fuel and brake lines, belts, hoses, and vacuum lines for dry rot or seizure. Put oil or penetrating fluid in the cylinders and turn the engine by hand before cranking, and have a knowledgeable person inspect it first.
Conversation Summary
The owner of a 1993 Mazda MPV that has not been started for three years asked whether returning it to the road would cause problems. Replies said problems are likely, including dry-rotted rubber parts, seized components, and brake or fuel-line issues. Recommended steps include checking for rodents, servicing oil, filters, and fuel, lubricating the cylinders, and turning the engine by hand before attempting to start it.
