1992 Mazda MPV Runs but Won't Move
MPRATT
I have a 1992 Mazda MPV. It started up, I drove it about 1/2 mile and then it would move. It was still running. What might be wrong?
Jan 23, 2006 at 11:13 PM
2CARPRO JACK
  • 11,533 POSTS
transmission
Jan 24, 2006 at 9:35 AM
JESSESON
  • 5 POSTS
I suggest you check the transmission fluid level 1st. If the fluid level is okay and there are no leaks, you've got major transmission problems.
Jesse
Apr 28, 2006 at 2:58 PM
Suggested Repair
Check the transmission fluid level and look for leaks. If the fluid level is normal and there are no leaks, the transmission likely has a major internal problem and should be professionally diagnosed.
Conversation Summary
The owner of a 1992 Mazda MPV reported that the vehicle started and ran, but after driving about half a mile it would no longer move while still running. Experts identified a transmission problem and advised checking the fluid level first; if the level is okay and there are no leaks, major transmission problems are likely.
