1991 Mazda MPV Engine Dies at Speed
DRBEANE
1991 MPV, 4W/D 6cyl, 159,000 miles. After 5 to 10 miles of freeway speed the engine dies. Waiting for a minute or so and it will restart. Engine dies again when returning to freeway speed for a few miles. What could be happening?
May 1, 2006 at 5:35 AM
LOSONE
  • 1,616 POSTS
No real idea but it may be an ignition moule that is over heating. If you car has an optical reader distributer than that is a likely culpret.
May 1, 2006 at 7:12 AM
DRBEANE
The problem turned out to be the ignition coil that died completely
May 17, 2006 at 1:15 AM
Suggested Repair
The confirmed cause was a failed ignition coil. Replace the ignition coil if the engine dies after freeway driving and then restarts after a short wait.
Conversation Summary
A 1991 Mazda MPV with a 6-cylinder engine died after 5 to 10 miles at freeway speed, then restarted after waiting about a minute and died again under the same conditions. An expert suggested an overheating ignition module or optical distributor reader. The owner later reported that the ignition coil had failed completely.
