1991 Mazda b2200 OIL SMOKE
110,000 MILES • 4 CYL • 2WD • MANUAL
CHEAPOH
JUST BOUGHT THE TRUCK AND CHANGED THE OIL AND FILTER, OF COURSE I DID NOT GET AS MUCH OUT AS I PUT IN BUT ANYHOW NOW IT SMOKED QUITE BADLY AND TAPERED OFF, AFTER TURNING OFF AND RESTARTING IT SEEMED LIKE IT IS OK NOW. I DID NOT OVERFILL ALS A LITTLE BIT OF WATER DRIPPED OUT OF TAIL PIPE AND ALSO WENT AWAY. I'M GUESSING HEAD GASKET
Oct 20, 2010 at 12:34 PM
SERVICE WRITER
  • 9,123 POSTS
Worn rings would be my first thought.
Does it tend to smoke on the first start up?
A little moisture coming out the tail is not abnormal. In the cooler climates and short driving distances it is normal. Not sure of your climate.
Oct 20, 2010 at 12:45 PM
