excessive smoke only when starting up in morning
200,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
SLUGGIE85
Only smokes when it's cold smoke is thick and has a blue hue to it after it warms up it stops other then that truck runs great has new timing belt head gasket what's causing this problem please help thank you for your time
Dec 31, 2014 at 5:34 PM
WRENCHTECH
  • 20,758 POSTS
That's not a good sign at all. It means the engine is consuming large amounts of oil though a yet to be determined internal failure. I'm afraid the days of this engine's life are coming to a close.
Dec 31, 2014 at 9:11 PM
