Mazda 626 Lots of continuous white smoke
ABBENSON
  • 1962 MAZDA 626
Other Category problem
Mazda 626 4 cyl Front Wheel Drive Manual 184116 miles
This has happened to me twice, and always in the winter when the temperature is below 50, After I get an Oil change from JiffyLube.
When I start up my car huge plums of white smoke come out for at least 10 minutes then stops. My car runs the same, makes no bad noises, but sometimes I smell some type of fluid, oil maybe? But I never see Oil drip stains. I have looked in my engine compartment also, and I see some oil leakage around the engine, but would that affect the exhaust? Also this process is happened for at least 2 months well after the oil change
Tuesday, January 29th, 2008 AT 9:53 AM
MIKE H R
  • 3,094 POSTS
If you don't loose water or oil and the car runs fine after 10 minutes, I would suspect that when they change the filter or add new oil that some could have spilled onto the exaust and is burning off. This does happen some times.
Tuesday, January 29th, 2008 AT 10:32 AM
