Engine turns over but won't start?
BUCKEYENBAMA
  • 1998 MAZDA 626
  • 100 MILES
The car has been running rough at times and at other times it decides to cut off at low speed during stopping or pulling off. The other day the car quit running and would crank but not run. After towing home and checking code, P0320 was set. It is now 3 days later and went to look into problem, car started and ran.
Monday, July 6th, 2020 AT 7:47 PM (Merged)
  • 110,182 POSTS
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
BUCKEYENBAMA
Thanks, I check the code and found the same description. I did check the crank sensor as well by unplugging and the car would not run or start. Reconnected and it started. Noticed notches or teeth that the sensor reads are all evenly spaced except for one, as if it were missing a tooth, but doesn't appear to be broken off.
  • 110,182 POSTS
That is odd. They should be evenly spaced.
BUCKEYENBAMA
Any other ideas?
LONGROD
  • 1998 MAZDA 626
Car turns over but won't start. Checked fuel pressure and spark also compresion but still nothing. Sparyed starting fluid and still nothing any one know whats up? Or had same problem. Tried crank sensor not the problem. I found the problem the timing had jumped a few teeth on cam side do to the spring on the tensoner breaking. Yes the car had fuel, compretion and spark. But when its off on the cam side it can only turn over but will not try to start. Thanks for the help anyway merlin. Nothing was bent because the problem was on the cam side.
MERLIN2021
  • 17,250 POSTS
The car HAS to be missing one of these ingriedients! Not possible for an engine not to start with good compression good spark and good fuel! What were the compression readings and did you check all cyls, with all plugs removed? When you turn the key on, are you sure the pump runs for a few seconds? And lastly are the plug wires routed corectly?
MERLIN2021
  • 17,250 POSTS
If the chain jumed a tooth or two, you better not try to run it! You will damage internal engine parts.
THEGR8BRIT
  • 1998 MAZDA 626
  • 4 CYL
  • 198,000 MILES
How would I know if I had a faulty ECU? Is it possible for it to malfunction in only part of what it controls or would nothing work? Is it an all or nothing situation?
My car lost power on the highway, I noticed it had overheated & turned itself off. I coasted to the shoulder. It has never been able to turn over ever since. It cranks & I can see all the pulleys turning, etc, but just won't fire up.
I have replaced the spark plugs, thermostat, fuel filter, fuel pump to no avail. The fuses & relays seem to all be in order as well. A code reader I rented said their were "No Codes". I do however, have power to radio, locks, lights, windows, radio & a/c, etc.
I'm wondering if it's the ECU. I can not hear the fuel pump prime when I turn the key. We verified that fuel is not reaching the filter. Can part of an ECU get fried & yet have other things it controls still work?
We're just scratching our heads here.
Check and test both the main relay and the fuel pump relay, and engine fuse 15amp and EGI INJ 30amp
THEGR8BRIT
In my fusebox, there are:
Circuit
TNS
Air Con
H/L
Horn
EGI Main
I have tried to check them by switching them around. I know that my horn works as well as my H/L. So, I took those relays & tried them in Main, etc. No difference & horn, etc still worked w/ suspected relays in their place. Is this an ok way to check? The model #'s of the relays matched so I figured it should be ok.
The fuses all appear to still be intact.
I also wonder if my relays are in the correct order. I once saw a picture of someone Else's & the green one was in a different position. This was before I touched mine for testing. It must have worked because the car ran fine for years in that order. Just a curiosity.
HRAMOS25
  • 1998 MAZDA 626
  • 6 CYL
  • FWD
  • 144,000 MILES
I cant get my car to stART.I man a stop at a red light and it shut off on me.I tryed to start it up and no luck.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
2CP-ARCHIVES
  • 4,540 POSTS
  • 1998 MAZDA 626
  • 175 MILES
I was driving one day and my car just died on me and started smoking where the alternator is and when I tried to start it, it sounded like the belts were just spinning and my battery would die after trying to start it so many times. My engine light was on and so was my oil light. I checked why the engine light was on and it gave me a code for a bad thermostat and there was enough oil. Could it be a bad alternator that isnt making my car start or could it be the fuel pump. Please help me. Thank you.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure also check for fusible links burnt by alternator.
There is no code for bad thermostat. What was the number?
Remove the belt and see if it starts
TEDMAN
  • 1998 MAZDA 626
  • 6 CYL
  • FWD
  • 140,000 MILES
98 Mazda 626V6 cranks but won't start.
Cranks but no start condition:do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
