1991 Mazda 626 Hot No-Start
KCTECH
Hey Folks - I'm hoping someone can point me in the right direction here...
I just got a '91 626 which is in really excellent condition but didn't run. I have one just like it that runs really well, but the body is beat up bad. I was hoping to put the best of both together. The problem with the new one is that it starts when cold, but not easily, and it won't start at all when it's hot. It's the 4 cylinder non-turbo automatic LX model with the power/economy switch, which I've never seen before. It has about 180,000 miles on it. I've replaced plugs, wires, & filters just because that way I know it's done. I've pulled the timing belt cover; the belt is snug, and with the crankshaft pulley lined up to the notch, the top rocker pulley is lined up to the arrow on #1. Not sure if the ignition timing is right, but I got it close as I could statically - I'll have to be able to keep it running to really time it!
If it is cold, you can crank it for a while, and it might catch. If it catches and starts, it will run fine - A little hot, but not bad. But if you shut it off or it stalls, it will not start again.
I've checked, cleaned, and re-seated all electrical connections, and pulled off the manifold throttle body and cleaned it thoroughly.
Don't know what else to do, and the two books I have are no help.
Anybody want to try and point me in the right direction??? I'd be really grateful!
Thank you very much! KC
Aug 14, 2007 at 2:25 PM
  • 75,988 POSTS
[quote:6811ed5b27="kctech"]Hey Folks - I'm hoping someone can point me in the right direction here...
I just got a '91 626 which is in really excellent condition but didn't run. I have one just like it, but the body is beat up bad. I was hoping to put the best of both together. The problem with the new one is that it starts when cold, but not easily, and it won't start at all when it's hot. It's the 4 cylinder non-turbo automatic LX model with the power/economy switch, which I've never seen before. It has about 180,000 miles on it. I've replaced plugs, wires, & filters just because that way I know it's done. I've pulled the timing belt cover; the belt is snug, and with the crankshaft pulley lined up to the notch, the top rocker pulley is lined up to the arrow on #1. Not sure if the ignition timing is right, but I got it close as I could statically - I'll have to be able to keep it running to really time it!
If it is cold, you can crank it for a while, and it might catch. If it catches and starts, it will run fine - A little hot, but not bad. But it you shut it off or it stalls, it will not start again.
Anybody ant to try and point me in the right direction??? I'd be really grateful!
Thank you very much! KC[/quote:6811ed5b27]
Try checking the fuel pressure with a fuel pressure gauge calibrated for yours and com back with the results
Aug 14, 2007 at 3:17 PM
KCTECH
hey there!
Heading down to the Zone now to by a gauge and see what's up with the pressure.
Just tried it a while ago - Same thing... hard to start - Acts like it wants to, and then finally catches. At that point it will run smooth until it you turn it off, or it may drop idle and quit. At that point it won't start again.
So anyway, I'm off to by a fuel gauge.
Thanks for the tip - I'll post what I find out.
BTW - Is there a website with normal fuel pressure values? Anybody able to post them for me so I know what's good/bad?
Thanks!
KC
Aug 20, 2007 at 12:20 PM
  • 75,988 POSTS
[quote:06a66020fb="kctech"]hey there!
Thanks!
KC[/quote:06a66020fb]
Also check your fuel pump relay located in engine compartment main fuse block could be acting up
Fuel pressure should be 30-38psi
Good Luck
Aug 20, 2007 at 1:52 PM
Suggested Repair
Check fuel pressure with a gauge; it should be 30-38 psi. Also inspect the fuel pump relay in the engine-compartment main fuse block, which may be failing.
Conversation Summary
The owner of a 1991 Mazda 626 with about 180,000 miles reports hard cold starts and a no-start once the engine is hot. After it starts it runs acceptably until it is shut off or stalls, then it will not restart. Plugs, wires, filters, connections, and the throttle body were already serviced, and timing-belt alignment looked correct. The expert advised checking fuel pressure (30-38 psi) and the fuel pump relay in the engine-compartment fuse block.
