1997 Mazda 626
FRANCHIZE
  • 1997 MAZDA 626
Engine Performance problem
1997 Mazda 626 Automatic
Hello.I have a mazda 97' 626. Its currently out of commission right now.I havent drove it in a while since the last time it overheated and gave out on me. It had been giving me problems.I had to replace a bunch of belts n change out the whole power steering pump. In the midst of that, the mechanic told me I had a blown gasket n I should get this sealent called Blue somethin-or-nother. Anyway, I got it but it did nothing and he said I'd have to gt the gasket replaced. The car overheats and when I lift up the hood theres this white stuff squirted all over the engine. Looks like someone lifted the hood and splashed a can of white paint.I just wanna know if its the head gasket before I shell out all that money to fix it.I may just get rid of the car and bus it till I can get a new one. Rather not tho.I only had it for like a year.
Monday, February 9th, 2009 AT 11:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It has all the symptoms of a cracked head gasket. If mechanic performed proper tests to check for cracks in the head and head gasket then it definitely needs replaced.
Thanks for using 2CarPros. Com!
Tuesday, February 10th, 2009 AT 1:12 AM
