HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Astra
Engine
Mass Air Flow Sensor
SPONSORED LINKS
MAF erratic readings
PREV
1
2
NEXT
KEN L
MASTER CERTIFIED MECHANIC
If you have a new MAF sensor and still have the problem, it sounds like the PCM is bad. Please follow this guide to help:
https://www.2carpros.com/articles/how-to-replace-a-vehicles-main-engine-computer-pcm-ecm-ecu
Please go over this guide and get back to us.
SPONSORED LINKS
Monday, August 21st, 2023 AT 9:22 AM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Mass Air Flow Sensor Content
1999 Vauxhall Astra Beige Gundge On Oil Cap?
Hi There I Have A Mk4 Vauxhall Astra 99 T Reg And Have Noticed A Beigey Colour Gundge On The Oil Cap And A Little On The Dipstick, I Have No...
Asked by
anthsastra
1999
VAUXHALL ASTRA
GUIDE
A mass air flow sensor can become inaccurate after large amounts of air (high mileage) has passed over the hot wire and must be cleaned before normal operation will return...
2002 Vauxhall Astra Oil Pump Failure.
We Have Had Our Car Diagnosed With Oil Pump Failure, The Bolt Came Loose On The Pulley Causing The Pump To Fail, We Drove The Car Around...
Asked by
dionne90
2002
VAUXHALL ASTRA
2001 Vauxhall Astra Oil Cap
Engine Problem 2001 Vauxhall Astra Engine Size Unknown Front Wheel Drive Manual 58000 Miles The Inside Of My Oil Cap Is Milky White....
Asked by
mick987
1 ANSWER
2001
VAUXHALL ASTRA
How Can I Tell If The Mass Flywheel Has Failed Or If...
How To Know The Difference If My Dual Mass Flywheel Has Failed Or If My Clutch Is Failing. I Know The Flywheel Would Cause Damage To Clutch...
Asked by
Ashley Chell
2010
VAUXHALL ASTRA
Can A Faulty Starter Motor Stop The Car
And Stop It From Cranking Over Even Though The Ignition Lights Come On? My Car Cut Out But The Lights On The Dash Come On But It Won't Crank...
Asked by
19matty79
2001
VAUXHALL ASTRA
VIEW MORE
SPONSORED LINKS
Mass Air Flow Sensor Replacement
Mass Air Flow Sensor Ford F150 2004-2008
Mass Air Flow Sensor Service
Online car repair manuals
