HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Symptoms
Locked Up
Locked up engine?
PREV
1
2
NEXT
CANNON1349
MECHANIC
Yes I do stay busy, thank you.
I can't find anything that says it's an interference engine, only mycarangel. Com saying it could be noninterference. So I don't know what to believe.
Tuesday, September 15th, 2020 AT 5:52 AM
MECHANIC
Pull a plug and use a boroscope into the cylinders and check for the valves being bent or damaged.
Tuesday, September 15th, 2020 AT 5:55 AM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Locked Up Content
I Can't Get My Engine To Rotate By Hand To Set The...
I Installed A New Oil Pump And Torqued The Cover To The Correct Torque. I Also Installed A New Water Pump And Torqued It To 82 In/lb Top...
Asked by
granolavsraisins
1994
TOYOTA CAMRY
GUIDE
Engine Rotation Test
One of the more basic tests for an engine that will not crank over is the "manual rotation test". This is used for confirmation that the engine has not suffered a mechanical...
My Car Will Not Start. All Lights And Radio Work
My Car Will Not Start. All Lights And Radio Work. I Check The Battery Cable And It Is Not Loose.
Asked by
Michelle Shine Robinson
1 ANSWER
2012
TOYOTA CAMRY
Drop In Gas Mileage Per Gallon (from 30 To 22)
Dealership Claims That When A New Battery Was Installed (not By Them), The Computer Was Not Set Correctly. The Dealership Disconnected The...
Asked by
thechucker
2012
TOYOTA CAMRY
Power Comes And Goes Between Rpm 1000 - 2000
Hi Guys, V6 ( 3.0l) Automatic. Mileage: 127000. The Car Starts And Idles Well. However, When I Drive Slowly With The Rpm In The Range...
Asked by
sahan_a
2012
TOYOTA CAMRY
It Won't Start.
The Engine Turns Over But Doesn't Start. It Is Getting Fuel. I Also Get A Spark To My Spark Plugs. It Is A 4cyl Le
Asked by
rfendrick
1994
TOYOTA CAMRY
VIEW MORE
Engine Oil Change and Filter
Engine Oil Change and Filter Replacement
Engine Oil Replacement Honda Accord
