2000 Lincoln LS Coolant Leak
72,000 MILES • V8 • 2WD • AUTOMATIC
WB026473
I have a 2000 Lincoln LS that has started to overheat. I'm seeing coolant leaking on both sides of the engine at the valve covers. Im guessing it is coolant, but it looks like a mixture of oil and water. Does this mean it needs a new water pump, head gasket ? The thing that baffles me is that it is leaking from the same place on both sides of the engine.
Apr 7, 2009 at 2:38 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me your engine size in liter.
Is it blowing white smoke too and running rough?
If you are losing coolant like that then yes I am sad to say, it appears as though you have a blown head gasket…both sides.
Pull a spark plug and see if there is water in the cylinder.
Apr 7, 2009 at 8:08 AM
WB026473
3.9L V8, the car tries to stall when you give it gas. If you hold the accelerator around 2500 RPMs it will start pulsing and yes some white smoke.
Apr 7, 2009 at 8:21 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the information. I am afraid based off of what you are saying you have a blown head gasket. White smoke out the tail pipe is another sign.
Apr 7, 2009 at 4:03 PM
