2000 Lincoln LS Water Pump
2000 LINCOLN LS
172,000 MILES • 6 CYL • AWD • AUTOMATIC
LEEROYD06
How do we know if the water pump is going out? I have a noise as if the power steering is going out. There is a noise that is coming from underneath my car.
Dec 14, 2008 at 8:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Overheating/underheating, coolant leaking, squealing are all signs of bad water pump. Check coolant level and check for coolant leaks near pump. It could just be worn bearings in one of the pulleys.
Dec 14, 2008 at 8:18 AM
