When the air temp. is about 50 Degrees or lower the CHECK RIDE CONTROL warning comes on. I reset the warning and it stays off until the car sits for an extended period of time in the cold. The compressor doesn't seem to run more then normal and the system seems to be OK. Thanks.
Nov 18, 2007 at 6:22 AM
