Okay, the misfiring might have damaged the engine some. The misfires can dump extra fuel into the cylinders and cause the oil to get diluted some as well as wash the oil off the cylinder walls and cause the rings to wear and then the engine starts burning oil.
I would suggest doing both a compression and leak down test on the engine to determine if that is the case. I suspect this more than other reasons because you say it starts smoking more as the engine warms up. That means as the oil gets thinner it can bypass the rings easier. One thing to try first, do the tests then change the oil and filter. Sniff the oil on the dip stick and see if it smells like gas as well. That would really indicate that it needs an oil change.
Aug 28, 2022 at 7:32 PM
