Leaking a lot of coolant
1997 MERCURY COUGAR
250,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
DEBWALDEN
I have a leak somewhere because i have to add coolant every other day. Not a lot, but always seem to have to top it off. It has been that way for a few years. Husband replaced the radiator and water pump when it started leaking but the leak was still there. This past two weeks the temperature has been in the twenties. I drove to work and and I did not have any heat, it was blowing great but it was cold. I looked at the temperature gauge and it was almost at the hot. It usually never comes the cold so I did not think the gauge even worked. Husband checked the coolant and had to add a Gallon. We left the car sitting for three hours and when we checked the coolant again it was gone but we cannot see where it is leaking. Checked the oil to see if there is water in it and there is not. He started the car and added more coolant, we could see some steam coming up right in front of the firewall on the drivers side. It looked like coolant was dripping off something and landing on the catalytic converter. Would there be a freeze plug back there? Where could the coolant be leaking from so close to the firewall? Please help this is my car and he said if it is the head gasket leaking he is driving it to the scrap yard.
Jan 3, 2018 at 8:57 PM
Good morning.
The first thing I would do is to get a pressure tester and pressure test the system. you can rent one at a parts store. In most cases it is just a hose that causes the leak. It may be something simple. If it was a head gasket the car would smoke out the exhaust.
Jan 4, 2018 at 1:55 AM
RENEE L
  • 1,260 POSTS
Hello DEBWALDEN,
Here is a link to a great instructional article from this site for pressure checking your cooling system. This article features step by step instructions with pictures and a video.
https://www.2carpros.com/articles/radiator-pressure-test
If you need further assistance please feel free to come back to 2CarPros we are always happy to help.
Have great rest of your day!
Kindest regards,
Renee
Admin
Jan 4, 2018 at 2:29 PM
