2001 Land Rover Discovery 2 s and m lights flashing
20,040 MILES • V8 • 4WD • AUTOMATIC
DOE
The s and m mode lights flash. Car runs poorly and cuts off and will not start. After 30 or so minutes it cranks. Battery is new and have cleaned battery connections. Have had car checked to see if alternator is charging and it is. This seems to happen at lower speeds and a clunk noise is heard and the lights begin to flash and then have to get off the road.
Mar 6, 2009 at 2:56 AM
ROVERTECHGOLD
  • 20 POSTS
THE S AND M LIGHTS ARE MODE LIGHTS FOR THE TRANSMISSION. I WOULD RECOMMEND GETTING THE FAULTS CODES PULLED FOR THE ENGINE AND TRANSMISSION. ONCE YOU HAVE MORE INFO YOU CAN GO FROM THERE.
Mar 19, 2009 at 6:01 AM
DANIELSOLIS
i have a similar problem with my 2000 v8 discovery 2. i found out that it is in sport mode. i followed directions on a previous site to place in high gear then reverse for 20 ft. I have checked the transmission fluid while running in neutral and is a darker red color but full on fluid. it seems when it heats up it goes into this mode. I have taken in to a full service shop and they could not figure out reason for this but told me it would be the crank sensor. i would really appreciated your suggestions on this. Thank you.
Jan 17, 2013 at 10:43 AM
