2000 Kia Sportage Stalls After Start
KIA
J.P.
  • 20 POSTS
Hello my 2000 Kia sportage all of a sudden developed a problem.it has 69,500 miles on it and it runs fine shakes slightly when running however,the past week or so, it would start, idle for about 10 sec and then stall. When I go to start it, it cranks fast but won't start. It will only start after I crank it for a while. Then it runs. I'm not sure if it will do anything, but I was going to replace the plugs, wires, fuel filter and air filter.I already replaced the PCV Valve. I'm the 2nd owner and have never given it a full tune up yet. Any ideas if this might work? I was told that maybe I have water in the fuel, but I'm not to convinced... Please help so I can get rid of this thing and buy a Honda. Thank you for your time... Also is there anything else I should do for the tune up?
Feb 13, 2006 at 1:48 AM
2CARPRO JACK
  • 11,533 POSTS
looks at the plugs for a rich condition
Feb 14, 2006 at 9:17 AM
J.P.
  • 20 POSTS
Hello it's JP again. I gave the Kia a tune up. Fuel filter,Plugs & wires,air filter and engine oil. It started on a dime. Ran smooth and everything. When I woke up this morning to goto work, it started in one shot, ran for about a minute and then it stalled. When I went to go and start it again, it wouldn't start. I then pump the gas pedal about 3-4 times and then it started. I'm not sure if it was a coincidence but it worked....4 hours later I go and try to start but it won't stay running.... Any ideas? Fuel pump relay maybe? Fuel pump? Is it the 15AMP relay located under the hood's fuse box?
Feb 17, 2006 at 12:22 AM
CODY-ODY
  • 57 POSTS
you can try the relay (they're really cheap) and also you can check the ground wires at the fuel pump cover lid located under your rear seat and has a material pull back cover.
Also you should check to see if you have any trouble codes in the computer,this will help greatly in locating the problem if you have a code stored.
And by the way after woring for Honda for a very long time and now for Kia you wouldn't be "upgrading" very much if you compare the two nowadays!
Jul 10, 2006 at 12:06 PM
Suggested Repair
Inspect the spark plugs for a rich condition. Try the inexpensive fuel-pump relay, check the ground wires at the fuel-pump cover under the rear seat, and scan for stored trouble codes.
Conversation Summary
A 2000 Kia Sportage with about 69,500 miles starts, idles briefly, then stalls and may need extended cranking to restart. After plugs, wires, fuel filter, air filter, and oil were replaced, it still stalled and sometimes restarted after the accelerator was pumped. Experts advised checking the plugs for a rich mixture, trying the fuel-pump relay, inspecting the fuel-pump grounds under the rear seat, and scanning for trouble codes.
