1995 Kia Sephia No Start
KIA
ADOLFO
1995 kia sephia 1.6 .98000 miles. replaced fuel filter, plugs, wires, rotor and cap several times recently because it has falied to start about every 2 weeks for the last 2 months. The motor runs smooth, no hesitatiion. When it does not start i remove the plugs to find them wet with gas. Compression was done...125, 175, 185, 165. This time it will not start with clean plugs. They keep getting wet with gas and soot. Runs very well for 2 weeks at a time. Out of options. Please respond. Thanks Adolfo
Jan 24, 2007 at 5:13 AM
BRUCE HUNT
  • 3,754 POSTS
Quite wasting money on plugs and other items. The car doesn't want to run because of any electrical problem. It is getting gas but I would bet it is getting no spark during this no start period. Next time this happens, take an old plug and hook it to one of the plug wires and touch the firing tip to the engine block. Turn the engine over and look for a spark, a strong blue arc.
Jan 24, 2007 at 8:12 AM
Suggested Repair
Stop repeatedly replacing plugs and ignition parts. During the next no-start, ground an old spark plug to the engine block and crank the engine to check for a strong blue spark.
Conversation Summary
The owner of a 1995 Kia Sephia 1.6 reports intermittent no-starts about every two weeks. The plugs are wet with fuel, compression readings vary, and the engine runs well between failures. The expert says the problem is likely loss of spark rather than fuel and recommends a grounded-plug spark test during the next no-start.
