Jerking
CEHAYNES
Yes the engine size is correct. I'm hoping it not the catalytic converter. Would that cause the car not to start?
Tuesday, October 23rd, 2018 AT 6:32 PM (Merged)
CEHAYNES
Oh yeah and it turns over, but doesn't seem to be getting any connection to start. Could a faulty spark plug wire cause all the plugs to go out?
CJ MEDEVAC
  • 11,005 POSTS
Ya Know, I bet gstacey's eyes are are "misting" also!
I've seen gstacey in action before!
During diagnosis, he throws out questions. The question asker ---"ACTUALLY"--- performs a check or test and returns with an answer. Not 2 more questions?
I can sorta relate that sorta questioning, to us maybe asking if your neighbor's car is roadworthy, think he will take you to work?
This is 2car. And that would be a solution!
Most of the time, the requested info, is sorta thrown out there, in an order or sequence, as to QUICKLY and EFFICIENTLY figure out what is wrong.
Assumptions, and bouncing from one possibility to another, generally has you spending $$$ on unnecessary parts and labor, not too mention prolonged down time!
I do not know if he was about to get there, but is your check engine light on? Have you had your codes read. This can be performed at many popular auto parts stores.
If you'll just say "how do you do this, etc", many of us here, can possibly explain or link you to something that might aid you!
Sorry gstacey, for butting in, I'll just kick back now, and watch. And see if the testing and looking get done!
The Medic
FACTORYJACK
  • 4,159 POSTS
When you first stated 'wouldn't crank', I started thinking of the possibilities that would cause stall and no crank(i.E. Hydrolock, no charge). Often times the common misconception lies between the words 'start, crank, and turn over'. Yes this could be a catalytic converter, that would cause sporadic cylinder misfires, low power, and in severe state a 'crank, no start'. Best DIY isolation, remove the oxygen sensor 'before' the catalyst, start and run the vehicle, and re-evaluate the symptoms.
DRIVER2004
  • 2004 CHEVROLET IMPALA
  • V8
  • 78,200 MILES
My car is jerking when we take of from a stopped position it also jerks while driving. The jerk range from hard to very gentle. What could be the problem?
RHALL77
  • 3,361 POSTS
Is there a check engine light on. Have the engine scanned for a possible engine misfire.
NURSEJDAVIS
  • 2002 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 140,000 MILES
Around 45mph my car will jerk until I give it gas to stop jerking. It also does this at 55, 65, 75 it seems like it does it when I try to stay at one steady speed but the only way to stop the jerking is to hit the gas.
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
GPAYNE
  • 10 POSTS
Try disconnecting the battery cables for about 4 hours. Worked for mine.
ADAMD1980
  • 7 POSTS
  • 2003 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 102,500 MILES
Recently my car has started almost slamming or jerking into gear. Its not doing it constantly. My guess is its doing it after the car has been running for a little bit. The car seems to jerk more when going into the final gear around 45mph but will also do it just not as bad around 20-25 and 30-35. I tried putting the car in first gear and driving and it would seem to do fine till I manually shifted into 2nd and then into 3rd and then final gear. Theres other days it didnt do it at all. I looked at the trans oil and while it doesnt smell burnt it does seem a little dirty. I have not had a flush and filter change in about 50,000 miles. I was planning on doing this myself. My main concern that it could be something else. The reason I think that it could just be with the filter is its inconsistency at times. But once it starts doing it I know exactly when its going to do it again. Any advice on this would be appreciated.
DAVE 256
My transmisson was fine untill the dealer talked me into letting them flush it. Then it started shifting hard. Took it back they said the pressure silenode was bad.(They glogged it up when they flushed it) after replacing it shiftes like new less 600.00 out of my pocket.
DOCHALL21
  • 2008 CHEVROLET IMPALA
  • 5 CYL
  • 120,000 MILES
Misfire occurs when car is idleling or when you pull up and stop. Car doesn't have a misfire when you excerate or you are driving down the road at any speed. We have checked the coil, sparkplug wires, intake manifold & gaskets for leaks.
Clean out the idle air control valve and EGR and PCV valves and also clean the MAF sensor with an electronic cleaner CRC and see what happens
RFB768
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 96,000 MILES
I changed fuel filter, plugs and wires still misfiring. Please help
RENAUDTN
  • 636 POSTS
Have you checked your intake vacuum?
NWINTON89
  • 2009 CHEVROLET IMPALA
  • 3.5L
  • V6
  • 98,350 MILES
Hi I have a 2009 impala and I just hot it not long ago and recently it has been doin a hard take off feeling like aomeone hit me from the back amd I can here the transmission trying to change gears then jerks into gear. What can cause this problem
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge auto parts rent it
