1993 Jeep Wrangler Oil Pressure Fluctuates
BRADH
I have a 93 Jeep Wrangler with the 4L inline 6 engine with 137000 miles. Every time I reach 45mph my oil goes to 80 once I reach 50 it goes back to normal and if I drive at 40 my oil pressure is normal. It randomly fluctuates when I drive to between 20 and 80. What is my problem, what should I do?
Apr 9, 2007 at 3:10 PM
  • 75,988 POSTS
[quote:9450caec1c="bradh"]I have a 93 Jeep Wrangler with the 4L inline 6 engine with 137000 miles. Every time I reach 45mph my oil goes to 80 once I reach 50 it goes back to normal and if I drive at 40 my oil pressure is normal. It randomly fluctuates when I drive to between 20 and 80. What is my problem, what should I do?[/quote:9450caec1c]
Maybe a bad oil sending unit-but have to be confirm with oil pressure check and could also be the gauge
Apr 9, 2007 at 6:05 PM
GPWHAT
I own two 93 wrangler's with the 4.0L one manual and one automatic and they also have extremly high oil pressure it does not seem to be a problem though
Apr 11, 2007 at 12:20 PM
  • 75,988 POSTS
[quote:6ccfccd788="gpwhat"]I own two 93 wrangler's with the 4.0L one manual and one automatic and they also have extremly high oil pressure it does not seem to be a problem though[/quote:6ccfccd788]
Could be the oil pump pressure relief valve
Apr 11, 2007 at 1:20 PM
Suggested Repair
Confirm actual oil pressure with a mechanical gauge. If the reading is false, check or replace the oil sending unit or gauge. If pressure is truly high or erratic, inspect the oil pump pressure relief valve.
Conversation Summary
The owner of a 1993 Jeep Wrangler 4.0 with 137,000 miles reported oil pressure rising to 80 around 45 mph, returning to normal near 50, and fluctuating between 20 and 80. An expert suggested a faulty oil sending unit or gauge, to be confirmed with an oil pressure test, and later said the oil pump pressure relief valve could be the cause. Another owner reported similarly high readings on two 1993 Wranglers that did not seem to cause problems.
