1999 Jeep Wrangler Sport (6-cyl; A/C); 50K miles on rebuilt engine.
At idle and operating temp, oil pressure drops to "0" and check guages light illuminates. Holding engine in the 1500 to 2000 rpm range will hold oil pressure at 20-25psi. Dip stick indicates proper oil level. No other symptoms. Water pump was replaced about a month ago.
Oct 29, 2007 at 8:42 AM
