1999 Jeep Wrangler LOW OIL PRESSURE
1999 JEEP WRANGLER
99WRANGLER
Engine Mechanical problem
1999 Jeep Wrangler 4 cyl Four Wheel Drive
Low oil pressure,replaced with high volume oil pump. checked main.&connecting bearing clearance, Is there a oil valley plug or screw missing ,maybe under timing cover?
Feb 20, 2010 at 3:04 AM
CJ MEDEVAC
  • 11,004 POSTS
What about installing a TEMPORARY/ PERMANENT ....MECHANICAL GAUGE... on your engine. The kind that has the ITY-BITY long plastic line..........run it thru your window for test....install permanent later if it's a bad factory gauge or sending unit.......OR..... fix what you have (gauge or sender).......Just some stupid advice......Love, Turddog
Feb 21, 2010 at 2:06 PM
