How to Repair Low Engine Oil Pressure
Engine oil is used to cool and lubricate bearing and machined surfaces. Without oil pressure an engine will experience extreme internal engine damage due to heat caused by friction. All engines run on a pre-set pressure that cannot be adjusted. This pressure will vary depending on engine speed, temperature and weight oil. As a rule of thumb, the engine oil pressure gauge shouldn't drop below 1/4 or exceed 3/4 pressure of the gauge.
Lets' Jump In!
To verify the engine oil pressure is low, start the engine (cold) and observe the gauge or light.
oil low pressure
Using the engine oil dip stick, check the oil level of the engine and ensure a proper level.
engine oil
The oil pressure switch is designed to send feedback data to the gauge or computer. These switches can go bad causing the gauge or light to show a false reading, remove the switch and insert a manual gauge to the engine and restart the engine. The gauge should read between 25 and 45 pounds.
oil pressure switch
The oil pump uses a screen to keep out impurities before entering the pump. If this screen becomes plugged with sludge due to lack of maintenance, the pump will scavenge causing low pressure. (Engine oil pan removed while turned over.)
oil pump pick up screen
The oil pump is also designed with an oil pressure relief valve and spring which regulates pressure. If this valve becomes faulty caused by a broken pressure spring the pump will have low oil pressure.
oil pump presure relief valve
An engine bearing is designed to support the crankshaft and other various engine parts while in motion. When these bearings wear, they can allow more oil to escape causing low oil pressure, this is a sign the engine has worn out and replacement or rebuilding is needed.
engine bearing
If the engine has no oil pressure, suspect the oil pump drive, some manufactures use a belt to drive the pump which are prone to failure.
oil pump drive belt
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
