2000 Jeep Wrangler Low Oil Pressure
Good luck and post back. :D
Good luck and let us know. :)
[quote:43c661e4f4="art alvarez"]i have a 99 jeep laredo, and today it started loosing oil pressure. the gauge drops when car is in idle, but goes back up when driving. i was told that it needs a new oil pump. i thought about changing the oil to see if that makes a difference but not too sure that will work.[/quote:43c661e4f4]
Suggested Repair
Have trouble codes read. Replace the oil pressure sender first, as it is a common failure. Verify actual pressure with a mechanical gauge to rule out the sender, lines, or gauge. Low pressure can also come from an underperforming oil pump or worn bearings, especially if ticking is present.
Conversation Summary
A 2000 Jeep Wrangler owner reported oil pressure falling near zero after warmup and at idle, plus a check engine light and rough running; an oil change did not help, and an expert advised reading codes. A 1999 Jeep Laredo owner then described similar idle pressure loss, ticking, erratic gauge readings after an oil change, hard starting, and 146,000 miles with no leaks. Experts listed a weak oil pump, worn bearings, or a bad sending unit as possible causes, recommended a mechanical gauge test, and advised replacing the oil pressure sender first.
