1997 Jeep Wrangler oil pressure guage
WALTER ABRAMS
  • 1997 JEEP WRANGLER
  • 4 CYL
  • 4WD
  • MANUAL
  • 78,000 MILES
Hello. I bought a 1997 jeep wrangler sport manual trans. When ever I stop at a light or slow down to a slow speed the oil pressure guage goes down to zero. This causes the check guages light to come on. I read other forums that said it might be the sending unit. Do you have any ideas before I take it to a mechanic or before I buy a new sending unit? What would be the worse case senario?
Wednesday, November 19th, 2008 AT 8:02 PM
  • 31,937 POSTS
Hi there.
Wost case is an engine re build as the bearings are failing, but as there is no reported bearing noise, I would get the engine oil pressure tested with a mechanical gauge to see what the actual pressure is, if it is OK, the sender will be at fault.
Mark (mhpautos)
Wednesday, November 19th, 2008 AT 11:54 PM
