1994 Jeep Wrangler High Oil Pressure
CHRYSLER
JEEPER15
I have a 1994 Jeep Wrangler with a new 4 cylinder that I have put approximatly 20k on since ive had it.
With the old engine, the oil pressure stayed and was maintained between 45-60 psi and with this new engine, at first it was also the same. After time it began to get lower around 30 psi at idle using 10w-30 (recomended) and would not go above 40psi while driving on the highway. I thought maybe it was due to the cold weather and changed to 5w-30 which is also recomended as an alternative for cold weather. After doing so the oil pressure went back to what I saw as normal operating pressure for my jeep which was around 45-60 psi, Recently however, after about 800 miles with the 5w-30 the oil pressure peaked the guage at 80 psi is this cause for concern and what might this mean, other than viscosities of the oils? :?:
Feb 28, 2007 at 8:41 AM
  • 75,988 POSTS
[quote:0b47887c14="jeeper15"]I have a 1994 Jeep Wrangler with a new 4 cylinder that I have put approximatly 20k on since ive had it.
With the old engine, the oil pressure stayed and was maintained between 45-60 psi and with this new engine, at first it was also the same. After time it began to get lower around 30 psi at idle using 10w-30 (recomended) and would not go above 40psi while driving on the highway. I thought maybe it was due to the cold weather and changed to 5w-30 which is also recomended as an alternative for cold weather. After doing so the oil pressure went back to what I saw as normal operating pressure for my jeep which was around 45-60 psi, Recently however, after about 800 miles with the 5w-30 the oil pressure peaked the guage at 80 psi is this cause for concern and what might this mean, other than viscosities of the oils? :?:[/quote:0b47887c14]
My opinion you're doing okay-perhaps the idiot gauge is acting up-out of calibration won't hurt to do an engine flush.
Anything less than 15lbs @ idle calls for concern-remember oil pressure will increase with rpm-the oil pump is spinning faster
Mar 2, 2007 at 5:47 AM
Suggested Repair
Verify the oil pressure gauge, which may be out of calibration, and consider an engine flush. Rising pressure with RPM is normal; concern is mainly if idle pressure falls below about 15 psi.
Conversation Summary
The owner of a 1994 Jeep Wrangler with a replacement 4-cylinder reported oil pressure dropping on 10W-30, recovering on 5W-30, then the gauge peaking at 80 psi after about 800 miles. The expert said the readings are likely acceptable, the gauge may be inaccurate, an engine flush will not hurt, pressure should rise with RPM, and concern starts below about 15 psi at idle.
