1950 CHRYSLER WINDSOR 4 DOOR SEDAN
1950 CHRYSLER
JOKER1904
I have a 1950 Chrysler Sedan. I want to switchthe frame for a more current one. Do you know what could fit it? I heard a Chevy Camero frame might fit but unsure what year? can you help?
Also I am planning on putting a Chrysler 360 engine or a Chevy 350 engine and conerting my car to a 12 volt system. Do I need to do anything so that I dont burn my Instrument panel? P.S. I plan on having an automatic (if that makes a diference to either question)
Thnank you,
Oct 1, 2007 at 1:19 PM
HMAC300
  • 48,601 POSTS
measure the wheel base of the car then measure something like a Dodge Dakota and se if the wheelbases are the same. A camaro is a unibdy car with a frame in the front only. If you do put a modern frame under it you'll have to move the body mounts from the old frame to the new frame.
Dec 17, 2009 at 6:12 AM
