1998 Jeep Wrangler Coolant Loss
M. BLANCHETTE
I have a 1998 Jeep Wrangler 4x4 with a 2.5 4 cylinder engine and 5 speed man. transmission. It currently has 106,500 miles. I seem to be losing coolant but can not find any external leaks (eg: loose hose, failed water pump, etc.). I have noticed, however, that when it's running in a stationary position water drips from the exhaust. Could there be an internal coolant leak making its way to the exhaust? If there is how extensive of a repair is it?
Sep 18, 2007 at 5:28 PM
  • 75,988 POSTS
[quote:8ac8011e89="M. Blanchette"]I have a 1998 Jeep Wrangler 4x4 with a 2.5 4 cylinder engine and 5 speed man. transmission. It currently has 106,500 miles. I seem to be losing coolant but can not find any external leaks (eg: loose hose, failed water pump, etc.). I have noticed, however, that when it's running in a stationary position water drips from the exhaust. Could there be an internal coolant leak making its way to the exhaust? If there is how extensive of a repair is it?[/quote:8ac8011e89]
What's happening is if its not condensation I would say a crack head or block and a blown headgasket.
Estimates: Part/s about $26.00 Headgasket
Labor 4.5hrs
Rate/Varies with location $50-$125 per hr.
Sep 18, 2007 at 8:55 PM
Suggested Repair
Confirm the exhaust drip is not normal condensation. If coolant loss continues with no external leaks, inspect for a blown head gasket or a cracked cylinder head or block. A head gasket is estimated at about $26 in parts and roughly 4.5 hours of labor, with shop rates varying by location.
Conversation Summary
The owner of a 1998 Jeep Wrangler 2.5 with about 106,500 miles reports coolant loss without visible external leaks and water dripping from the exhaust while idling. The expert says that if the drip is not condensation, the likely cause is a cracked head or block and a blown head gasket, and gives a rough parts and labor estimate.
