2001 Jeep Wrangler P0300 Misfire
jim
spec is 44-54 while idling
there are many things that will cause this problem , if fuel pressure checks out , check compression
Suggested Repair
P0300 is a random misfire, not an EGR fault. With ignition parts, sensors, fuel pump, coil, and the circuit board already replaced, and with fuel pressure and compression reported in spec, inspect the injector harness connectors for looseness—especially cylinder 2—and do a wire shake test while the misfire is present.
Conversation Summary
The owner of a 2001 Jeep Wrangler 4.0L asked whether an EGR valve could cause a P0300 code and a rough miss around 3000 rpm at highway speed that clears after a short shutdown and restart. The expert said P0300 is a random misfire, not an EGR code, and suggested a tune-up, fuel pressure of 44-54 psi at idle, and a compression test. The owner reported those items and several parts already checked or replaced and within spec. The expert then suggested a wire shake test of the injector harness, noting a similar case at the number 2 injector plug. The owner could not reproduce the fault that way; the light flashed at speed, went out when accelerating, and often returned when decelerating. No confirmed repair was reached.
