Wrangler engine trouble, working, single mom needs advice
JEEP WRANGLER
MTNLOVERJEEP
I'm the original owner of my wonderful 1997 Jeep Wrangler, V6, 4.0 L, with 200K miles, has been doing these things: when I press the gas pedal, it "humps" back and forth violently. Outside temps range about 70 degrees average. The mechanic put it on the scope, said cylinder 2 shows misfire. (It idles rough also.) He checked the fuel injectors and said they're fine. He replaced all sparkplugs, and wires. He put a bit of marvel oil in it, because he thinks the valve 2 is sticking, causing the misfire in cylinder 2. He also added fuel injector cleaner. Afterwards, the check engine light now stays on, and didn't before I took it in. It still acts like it's not getting fuel, especially in the first 3 gears. Once it's at speed on the freeway in 5th gear, it's fine. The mechanic suggested an engine rebuild, since he thinks the valve 2 is sticking. He doesn't do engine work, so it's definitely not a situation of him scamming money. He's a very nice guy and a good mechanic, but he couldn't fix the problem and I don't know whether to pursue an engine rebuild or if it's just the fuel pump, which he says it's not. But, would a faulty fuel pump cause the engine to act like it's not getting gas just in the lower gears and would it cause the engine to run rough at idle? Should I get a valve job and the fuel pump replaced? Thanks a lot for your advice.
Jan 28, 2007 at 3:36 PM
SERVICE WRITER
  • CAR REPAIR CONTRIBUTOR
  • 9,123 POSTS
I have seen th 4.0 motors with misfire problems. I have found that a Professional fuel injection cleaning and /or air induction service makes a difference on these.
The fuel injection service involves disconnecting the pump from operation and running a cleaner through the motor. We use Castle brand rail power, although there are others.
Jan 28, 2007 at 6:17 PM
