1998 Jeep Cherokee Clunk When Turning
JEEP
MARTYXJ
I have a 98 Jeep Cheerokee with 85,000 miles. It is 4x4, w 4.0 and auto tranny. I am hearing a clunking noise, especially at low speeds when turning, such as parking. I also have some vibration at around 70mph. I didn't know if the front driveshaft u-joints would clunk at low speed or if that would be the axle u-joints? Thanks.
Jan 12, 2007 at 9:13 AM
SERVICE WRITER
  • 9,123 POSTS
Probably the outer wheel joints. Slide under and turn the shaft with one hand and hold the other end of the joint area with the other, look for play in the joints.
Jan 12, 2007 at 9:21 AM
Suggested Repair
Inspect the outer wheel joints for play by turning the shaft with one hand while holding the joint area with the other. The clunk is more likely from the outer wheel joints than the front driveshaft U-joints.
Conversation Summary
The owner of a 1998 Jeep Cherokee with 85,000 miles reports a clunk at low speeds while turning, such as when parking, plus vibration around 70 mph, and asks whether front driveshaft or axle U-joints are the cause. The expert says the outer wheel joints are the likely source and recommends checking those joints for play.
