1998 Jeep Cherokee Cold Squeal
COCO
1998 Jeep Cherokee has a very LOUD squeal when cold. Squeal seems to come from engine/belt area, but belt has been replaced and adjusted 4 or 5 times with no result. After driving 5-6 miles (usually at 35 mph) the squeal is not as loud, but still there. Squeal is loudest when gas is applied or going up h ills. Squeal is not as loud when "coasting."
Nov 19, 2007 at 5:51 AM
MERLIN2021
  • 17,250 POSTS
The Jeep should have a serpentine belt, I would get the tensioner arm and pulley replaced, and while the belt is off, check all pulleys for and binding...if any are bining fix those problems too.
Nov 19, 2007 at 5:55 AM
Suggested Repair
Replace the serpentine belt tensioner arm and pulley. With the belt off, check all pulleys for binding and repair any that bind.
Conversation Summary
A 1998 Jeep Cherokee has a loud squeal from the engine/belt area when cold. The belt was replaced and adjusted several times with no improvement. The noise is quieter after 5-6 miles but remains, and it is loudest under acceleration or uphill and quieter when coasting. The expert recommends replacing the tensioner arm and pulley and checking all pulleys for binding with the belt removed.
