1999 Jeep Cherokee AC Squeal
TWOTONESHOES
Hi
I have a 1999 jeep cherokee sport. It has about 130.000 mi and a straight 6 cyl. 4.0.
My air conditioning unit squeals when I start the car. It takes a few hundred feet for it to stop. Otherwise the unit works fine. Good strong fan and excellent cooling but the squeal is getting worse and more prolonged. If the car is warmed up it won't happen but if I let it sit for a while and re-start it there it is again. I've heard that you can get some coolant that has lubricant mixed in. I would appreciate any suggestions.
Thanks!
J
Jul 4, 2007 at 4:43 AM
SERVICE WRITER
  • 9,123 POSTS
Need to determine what is making the noise, especially since it is getting worse. It is likley a belt or pulley. When the noise is happening, spray some water on the belt and see if it stops. Check to see if the tensioner is straight or cocked. Post back if nothing turns up.
Jul 5, 2007 at 1:49 AM
Suggested Repair
The squeal is likely a slipping belt or a pulley/tensioner issue. While the noise is present, spray water on the belt and note whether it stops. Also check that the tensioner is straight and not cocked.
Conversation Summary
A 1999 Jeep Cherokee Sport with the 4.0 engine squeals from the air conditioning system for a short distance after a cold start. Cooling and airflow remain strong, and the noise does not occur when the engine is already warm. The expert says the cause is likely a belt or pulley and recommends spraying water on the belt during the noise and checking whether the tensioner is straight or cocked.
