not cranking
JEEP
SERVBOTR6
my mom has a 200 jeep sport 4.0 with 100,000 miles i replaced the plugs and the fuel pump and still i see no spark or do i see gas come out of the small valve on the fule rail.Also the odometer reads no bu 5 What is the problem? i cant figure it out.
May 17, 2007 at 1:52 PM
SERVICE WRITER
  • 9,123 POSTS
You say the engine is NOT cranking?
Meaning when you turn the key, nothing happens?
May 18, 2007 at 12:36 AM
  • 75,988 POSTS
No ignition and Fuel-lets try the crankshaft position sensor-this baby tells the computer to fire the coil and pulses the injector
https://images.2carpros.com/forum/automotive_pictures/12900_RM182rt50_1.jpg
tor. Green Machine at work for Freedom
May 18, 2007 at 12:55 AM
SERVBOTR6
when i turn the key it turns over but nothing is happening it wont hit a lick. I will try the position sensor thanks. I will let yall know what happens.
May 18, 2007 at 10:51 AM
