1998 Jeep Cherokee Starting problem
SHUFFT
  • 1998 JEEP CHEROKEE
Engine problem
1998 Jeep Cherokee V6 Four Wheel Drive Automatic 110, 00 miles
Go to start the Jeep it turns over, but will not start until I put my foot on the gas pedal, once I take my foot off the pedal it dies. Sometimes if I continue to pump the gas, it will finally start running, other times it will not. If I undo the battery and reconnect it, it is as if I reset the computer, it will run for a couple of days, then it will start with the problem once again.
Monday, December 3rd, 2007 AT 12:05 PM
Check the coolant temperature and throttle position sensors to include the idle air control valve. This don't work might need a computer relearning all that time you're disconnecting the battery.
Tuesday, December 17th, 2019 AT 7:08 PM
