1999 Jeep Wrangler No Heat
JEEP
DDSUMMERS77
MY 1999 JEEP WRAGLER HEATER IS BLOWING COLD AIR IT HAS 100,000 MILES I TOOK THE HOSES OFF THE WATER PUMP AND STARTED THE MOTOR AND NO WATER IS COMMING OUT OF THE WATER PUMP BUT MY MOTOR IS NOT OVER HEATING IT IS A 4C
Jan 2, 2007 at 12:01 PM
SERVICE WRITER
  • 9,123 POSTS
Fill up the cooling system and see what happens.
Jan 2, 2007 at 12:05 PM
DDSUMMERS77
[quote="Service Writer"]Fill up the cooling system and see what happens.[/quote] IM SORRY FOR THE INCONVINCE. W.W.J.D
Jan 2, 2007 at 12:11 PM
SERVICE WRITER
  • 9,123 POSTS
No inconveince, I was not meaning to sound sarcastic and apologize if it did.
When you're not getting heat and you're not getting coolant coming out of the system when it's open, it sounds like it is low.
Why it isn't overheating I don't know.
Was there somthing I missed?
Jan 2, 2007 at 12:15 PM
Suggested Repair
Fill the cooling system completely and recheck heater output. No coolant coming from the open water pump suggests the system is low, which can cause no heat even if the engine is not overheating.
Conversation Summary
The owner of a 1999 Jeep Wrangler said the heater blows cold air. After removing the water-pump hoses and starting the engine, no coolant came out, although the engine was not overheating. The expert said the cooling system appears low and advised filling it and seeing what happens.
