1986 Jeep Comanche Transfer Case Clank
1986 JEEP
ABLACK7
i have a 1986 jeep comanche 4x4 2.6 v6 auto. for some reason when you go to put it in any gear but park something is clanking around inside the transfer case. so it will not move and i didnt want to buy a new case. i took the rear drive shaft off and the noise isnt as loud. could the chain be busted? if so how do i fix it? :)
Jun 25, 2007 at 1:42 PM
  • 110,251 POSTS
It sounds like the chain is broken. It's an involved process to check and replace if needed. I strongly recommend purchasing a repair manual that provides transfer case info. It should provide stap by stap instructions and pictures to help identify the parts.
Jan 15, 2009 at 5:37 AM
Suggested Repair
The transfer case chain is likely broken. Inspect and replace it using a repair manual that includes transfer case procedures, parts identification, and diagrams.
Conversation Summary
The owner of a 1986 Jeep Comanche 4x4 reports clanking inside the transfer case when selecting any gear other than park, and the vehicle will not move. Removing the rear driveshaft reduces the noise. The expert says the chain is likely broken and recommends a repair manual for the involved inspection and replacement process.
