1990 Chevy S-10 Transfer Case Leak
CAPTAINKID
1990 Chevy S-10 4X4 4.3 liter engine. my transfer Case is leaking fluid. the place it is leaking from i think has to do with the vaccuum line for the 4 wheel drive. their are three lines together. what would cause to leak and what is the name of the piece that the three line plug into at the transfer case.
Thank you
Aug 8, 2007 at 10:26 AM
CLY
  • 308 POSTS
First off check the trans fluid. You will probably find that it is low. There is a seal between the transfer case and transmission that keeps the fluids seperated.If that seal goes bad then the fluid from the transmission gets into the transfer case and causes it to be overfilled and t will leak out of the vent. I am not sure of the technical name for that vacumm switch assembly you are talking about.
Cly
Aug 8, 2007 at 11:10 AM
Suggested Repair
Check the transmission fluid level. If it is low, inspect the seal between the transmission and transfer case; a failed seal can let transmission fluid overfill the transfer case and leak from the vent. The vacuum-line connector was described only as a vacuum switch assembly, with no confirmed part name.
Conversation Summary
The owner of a 1990 Chevy S-10 4x4 with a 4.3L engine reported a transfer-case fluid leak near the three vacuum lines for the four-wheel-drive system and asked what causes it and what the connector is called. The expert advised checking the transmission fluid, which is likely low, and explained that a failed seal between the transmission and transfer case can let transmission fluid overfill the transfer case and leak from the vent. The expert was unsure of the technical name of the vacuum switch assembly.
