1987 Jeep Comanche Stalls After Running
It is a hard sensor to change,it is on the trans bell housing on the top,with a few extensions on your rachet you can get to it
It is a hard sensor to change,it is on the trans bell housing on the top,with a few extensions on your rachet you can get to it[/quote:f28c541bda]
quote from comanche21...
I agree with "rmaser", I had the same problem with my 1989 Jeep Pioneer truck I6 engine. It's tough to get to, but easy repair. On an automatic unbolt the bracket that holds the transmission cable and let it hang down, that will give you enough room. (A swivel extension or a wobble extension makes it easier). Good luck, comanche21.
From comanche21 (per merlin2021 quote)
Did check the date! But there are probably more than one person with this problem and the more suggestions the better as the answer I gave solved the problem.
Suggested Repair
Inspect the distributor wires, internal pickup, and shaft side play, and replace the distributor if needed. Also test the crankshaft position sensor hot and cold with a DVOM; if faulty, it is on top of the transmission bellhousing and can be reached with extensions.
Conversation Summary
A 1987 Jeep Comanche with a 4-cylinder and manual transmission starts and runs for 10 to 15 minutes, then stalls and will not restart for 45 to 60 minutes. The coil tested good and the ignition module was already replaced. An expert suggested checking the distributor wires, pickup, and side play. Other users reported the same symptom from a failing crankshaft position sensor on the transmission bellhousing. The expert later said a crank sensor is possible and should be tested hot and cold with a DVOM.
