1999 Chevrolet Tahoe Transfer Case Noise
HELOJUMPER810
My Wife's Tahoe has been acting up lately. Its making a weird noise at lower speeds almost like a grinding, and she says that one day it went in to 4 wheel drive on its own. The car place she took it too didnt know what to tell her, they drove it, put it on the lift, its not leaking, but still making the noise. They said to replace the transfer case, but im not sure i agree. It has 120,000 miles, and the 4 wheel drive hardly gets used. Its a 4 door, push button 4 wheel drive. i would love to help her and tear into it, but im deployed over seas. Thanks for the help.
May 18, 2007 at 8:52 PM
8052ROYC
  • 11 POSTS
My 1999 2dr Tahoe LT is in the shop at this moment with the same problem.
The trouble has been traced to a faulty selector motor on the transfer case itself.
The selector is not moving far enough to engage the 4x4 and is making a horible grinding noise.
Nov 16, 2007 at 9:14 AM
DENNYP
  • 1,824 POSTS
If it is auto 4WD,it could have a damaged clutch pack.This can be a result of driving in auto 4WD all the time.I would drain the fluid and make sure it is clean.If it's nasty,I recommend disassembly for inspection.It should only take a couple of hours.
Nov 16, 2007 at 11:31 AM
Suggested Repair
Drain the transfer case fluid and inspect it. If the fluid is dirty, disassemble the case and inspect for a damaged clutch pack, especially if it was driven in auto 4WD. A selector motor that does not fully engage 4WD can also cause grinding and should be checked.
Conversation Summary
A 1999 Chevrolet Tahoe with push-button 4WD grinds at lower speeds and once shifted into 4WD by itself. A shop found no leak and suggested replacing the transfer case. Another owner with the same symptom reported a faulty transfer-case selector motor that did not move far enough to engage 4WD. The expert said an auto-4WD clutch pack can be damaged by constant auto-4WD use and advised draining the fluid, then disassembling for inspection if it is dirty.
