2007 Jeep Liberty Blue Smoke
ARTPROF
I recently purchased a 2007 Jeep Liberty Sport with 3.7L engine, auto transmission. When the car sits for a few hours, upon starting, it emits blue smoke from the tailpipe for a few seconds. It is under warranty, so I will bringit to dealer, but am concerned that this may indicate a faulty engine, which over time may get worse. the vehicle has only 300 miles on it. Any advice would be most welcome.
Aug 23, 2007 at 4:14 AM
SERVICE WRITER
  • 9,123 POSTS
It is good to notify the dealer and have them verify this early on. Unless they find something, I would get through 3-5000 miles before being more concerned.
Aug 23, 2007 at 9:26 AM
LARRYJERI
car runs fine but is using oil [a lot] when idling for several minutes then you raise the engine it will smoke a lot for about 30 seconds and seams to quite smoking also after idling it will smoke under the hood. Is there a common cause for this as so many people are experiencing much the same thing?
Aug 16, 2019 at 6:37 AM (Merged)
HMAC300
  • 48,601 POSTS
check your pcv system first see if it has vacuum it may be plugged. check for an oil leak from valve covers
Suggested Repair
Have the dealer verify the early blue smoke on this low-mileage vehicle. Also check the PCV system for vacuum and a possible plug, and inspect the valve covers for oil leaks.
Conversation Summary
The owner of a 2007 Jeep Liberty with about 300 miles reports brief blue smoke from the tailpipe after the vehicle sits. A service writer advises having the dealer verify it early and not becoming more concerned until 3,000 to 5,000 miles unless a fault is found. Another comment describes heavy oil use, smoke after idling, and smoke under the hood. The expert recommends checking the PCV system for vacuum and a possible plug, plus checking the valve covers for oil leaks.
