1998 Jeep Laredo
JNOVACK
  • 723 POSTS
Ok now check you timming marks and also check the cam and crank sensors
Sunday, November 9th, 2008 AT 7:06 PM
VERN8650
  • 15 POSTS
I did replace the crank and cam sensors. Could the fuel pump not deliver enough volume? I have 49 psi at all times. I would like to check the pump for volume because the engine does hesitate to accelerate and the engine use to run strong but in the past 2 years it started to run with not as much power.
Sunday, November 9th, 2008 AT 7:58 PM
JNOVACK
  • 723 POSTS
44-54 PSI(Pounds per Square Inch) this is what the fuel pump should be putting out also check the fuel pressure regulator
Sunday, November 9th, 2008 AT 10:26 PM
VERN8650
  • 15 POSTS
Its putting out 49 psi. With no drop. The only thing I didnt try is putting the gauge up to the windshield and drive because my gauge is short. Ill try that next. If not I may bring it to a shop. Sometimes the hardest things for us do it yourselfers may be easy for a shop.
Monday, November 10th, 2008 AT 4:44 PM
JNOVACK
  • 723 POSTS
There is a service bulliten for the pcm software to be updated the pcm controls the ignition and other functions
Monday, November 10th, 2008 AT 6:52 PM
