You should really buy a manual, they are only $15 at the auto parts store. Does your vehicle turn over while tring to start or is it not cranking at all? If it is cranking over but not firing up, your Crank Position Sensor is probably the problem. It is located on the driver's side of your vehicle and ls located near the top of your transmission at the rear of the engine with one bolt attatched to it.
SPONSORED LINKS
Wednesday, March 17th, 2010 AT 9:38 AM
