1978 Jeep CJ7 6 cyl Four Wheel Drive Automatic? Miles
I did a compresion test to see what was wrong first I ran the motor till it warmed up then removed spark plugs starting from the ront of the jeep furthest away from the driver with the gas pedall to the floor turned it over for about ten seconds each cylinder and this is what I got 170 175 190 177 182 170 it will run good then just cut out or it will run then it will be just like the ide went real low at times then when driving it will die when stopping I tried to adjust the carb and get minimal results tried the timming, same thing I have playing with ths for what seems like years could it be he carb the plugs always look black like they are burning rich I looked for any vacum leaks and did not seem to find any also remember that this is not the firing order but from the front of the jeep towards the driver could the two cyl. That read 190 and 182 be clogged with carbon? Or is the carb bad and dumping to much gas into them or is this normal and just need a new carb? Please any advice is good thanks much TED
SPONSORED LINKS
Tuesday, April 29th, 2008 AT 6:53 AM
