1996 Jeep Cherokee Overheating
TWOJETSFLA
I have a 1996 jeep cherokee that is over heating....I've replaced the thermostat, drove it ten or fifteen miles overheated again....The top radiator hose is hot while the bottom hose is cool...What might be the problem?....Thanks for your help
Jul 23, 2007 at 12:02 AM
DPWD23
  • 136 POSTS
Begin by flushing the entire cooling system.
You will want to take out the thermostat and hook everything back up and give it a little spin w/o the thermostat. if you still have the top hot, bottom cool situation, you may have plugged radiator, or faulty water pump.
Jul 29, 2007 at 10:03 AM
MERLIN2021
  • 17,250 POSTS
Bottom hose should be cooler than the top! Check your thermostat again, make sure the spring is to the block!
Jul 30, 2007 at 9:00 AM
Suggested Repair
Flush the cooling system and confirm the thermostat spring faces the engine block. Briefly run the engine without the thermostat; if the top hose stays hot and the bottom stays cool, inspect for a restricted radiator or a faulty water pump.
Conversation Summary
A 1996 Jeep Cherokee overheats after 10 to 15 miles despite a new thermostat, with a hot upper radiator hose and a cool lower hose. One expert recommends flushing the cooling system and testing without the thermostat to check for a plugged radiator or bad water pump. Another notes that the lower hose should normally be cooler and advises verifying that the thermostat spring faces the engine block.
