1997 Jeep Grand Cherokee Won't Shift
PATRICIA M
I have a 97 Grand Cherokee Jeep I service it always on time.Tonight on my was home it didnt seem to want to shift into gears it is an automantic it has 150,000 miles on her. In drive it would only go about 25 to 39miles and hour. So I went into 2nd and it would only go about 29 to 25 when I got home and turned her off it smelled hot. I packed it out side of the carport. Help me Patricia M
Dec 3, 2006 at 12:15 PM
BOB WILSON
  • 13 POSTS
USUALLY WHEN AN AUTOMOBILE IS SERVICED, THE TRANSMISSION IS NOT INCLUDED IN THE SERVICE. THEREFORE IT COULD POSSIBLY BE A NEGLECTED TRANSMISSION. DID YOU MANUALLY PLACE THE CAR IN 2ND GEAR TO GET HOME? MANUALLY PLACED WITH THE GEAR SHIFTER WOULD PREVENT THE TRANSMISSION FROM REACHING 3RD GEAR HENCE THE LOW MPH YOU WERE ABLE TO OBTAIN. WITH THE ENGINE COLD, CK THE TRANSMISSION FLUID LEVEL. IF THE LEVEL IS IN THE CROSSHATCHED SECTION OF THE STICK AND THE FLUID IS RED WITH NO SMELL, IT IS NORMAL. BUT WITH WHAT YOU DESCRIBED, I WOULD SAY THE FLUILD IS LOW, BROWN, AND SMELLS BURNT. YOU WILL NEED A TRANSMISSION FLUID AND FILTER CHANGE AND LUCK. IF THIS DOESNT IMPROVE THEN MAJOR TRANSMISSION WORK IS LIKELY.
Dec 5, 2006 at 10:54 AM
CARUNDELL
  • 602 POSTS
[quote:4b58938583="patricia M"]I have a 97 Grand Cherokee Jeep I service it always on time.Tonight on my was home it didnt seem to want to shift into gears it is an automantic it has 150,000 miles on her. In drive it would only go about 25 to 39miles and hour. So I went into 2nd and it would only go about 29 to 25 when I got home and turned her off it smelled hot. I packed it out side of the carport. Help me Patricia M[/quote:4b58938583]
Hey Patricia,
Jeeps and Chyrsler transmissions will go into a"limp in" mode if there is a problem detected by the TCM(trans control module) and yours is in it!! I strongly recommend you take it to a professional and get it properly diagnosed before any permanent damage occurs!
Regards,
Chris
Dec 5, 2006 at 11:45 AM
SFCARLOSS87NG
hey i dont want to sound negative but the time for that trans could be up, i have a 94 grand cherokee, trans went right at around 150,000, it wasnt good, i lost reverse and 3-4 gears, good luck
Dec 9, 2006 at 2:06 PM
Suggested Repair
Have the transmission professionally diagnosed for limp-in mode from a TCM-detected fault before more damage occurs. With the engine cold, also check fluid level and condition; if it is low, brown, or burnt, a fluid and filter service may help, but major transmission repair is likely if symptoms remain.
Conversation Summary
The owner of a 1997 Jeep Grand Cherokee with 150,000 miles said the automatic would not shift normally, limited speed in Drive and 2nd, and smelled hot after the drive. Replies suggested checking transmission fluid and noted that Chrysler transmissions enter limp-in mode when the transmission control module detects a fault. The expert advised a professional diagnosis before permanent damage; another owner reported a similar failure near the same mileage.
