2001 Jeep Grand Cherokee Cylinder 7 Misfire Fix
KJMAHNKE
  • 5 POSTS
I have a 2001 Jeep Grand Cherokee V8- 78,000. A Couple of weeks ago i had a rough idle and a check engine light. Scanned to find that i had a misfire on cylinder seven. I changed plugs and moved coil pack from cylinder seven to cylinder one, reset computer and drove. Check engine light came on again and still read cylinder seven. I brought it in and had a motor vac service done to clean the injectors and still have a rough idle and check engine light for cylinder seven. I then did a compression test and am only getting around 45 to 50 PSI on cylinder seven and not holding very well. Thinking it could be a burnt or stuck valve and may bring it in to have heads removed and rebuilt. Could the misfire have damaged the piston/ring/ and or cylinder to where when i do get full compression after the head rebuild that it would blow that cylinder out, possibly from the unburnt fuel in the cylinder? What would be the best course of action now? Thanks very much :?:
Dec 26, 2006 at 8:58 AM
2CARPRO JACK
  • 11,533 POSTS
With only 78k on the odometer, I wouldnt hesitate to fix the valves and run it. It takes alot of driving with the fuel washing the cylinders to do any real harm.Sounds like once the MIL came on you took care of it promptly,so go ahead and fix it and enjoy your Jeep.Cheaper than a payment
Dec 26, 2006 at 11:34 PM
Suggested Repair
Repair the cylinder 7 valves or head and return the Jeep to service. At 78,000 miles, with the misfire addressed promptly, fuel wash is unlikely to have seriously damaged the piston, rings, or cylinder.
Conversation Summary
A 2001 Jeep Grand Cherokee V8 with 78,000 miles had a rough idle and a cylinder 7 misfire that remained after plugs, a coil swap, and injector cleaning. Compression on cylinder 7 was only about 45-50 PSI and did not hold well, leading the owner to suspect a burnt or stuck valve and ask whether unburnt fuel could damage the piston, rings, or cylinder. The expert advised repairing the valves and driving it, saying that much more driving with fuel washing the cylinder would be needed to cause real harm.
