1988 Jeep Cherokee High Idle
CAINMOS
I have a 88 Jeep Cherokee w/4.0L I6
When I start it, it will sometimes idle really high then if I give it a second will idle back down to the correct rpm. However, the other day it started to idle high while in drive as well. I had problems with the throttle sticking before but I checked it on the engine and it seemed fine. Could this be a vacuum leak, have yet to check for those, or some other type of problem?
Sep 23, 2006 at 4:46 AM
DEMEARSJR
  • 110 POSTS
Usually a vacuum leak around the intake manifold or the throttle body.
Oct 1, 2006 at 3:15 PM
BUBBA_KOSKI
  • 129 POSTS
if its not the vacc line, check the choke assembly she may be sticking, as well as the butterfly valve. then your fuel mixture screws.
_____________
ASE Certified
Advance Auto
9289
Oct 4, 2006 at 10:45 AM
Suggested Repair
Check for vacuum leaks around the intake manifold, throttle body, and vacuum lines. If none are found, inspect the choke assembly and butterfly valve for sticking, then check the fuel mixture screws.
Conversation Summary
The owner of a 1988 Jeep Cherokee with a 4.0L inline-six reported intermittent high idle after starting that usually settles, plus a recent high idle while in Drive. The throttle had stuck before but appeared fine when checked. Experts suggested a vacuum leak around the intake manifold or throttle body, and if vacuum lines are not the cause, checking a sticking choke and butterfly valve, then the fuel mixture screws.
