1996 Jeep Cherokee Headlights Fail
PORCELINA68
Last fall, when driving, my headlights would intermittently fail, and come back on after a few seconds. Soon after, whenever I pulled the lever to turn them on, there would be a small tendril of smoke coming out of the dash above the switch, and a very strong odor of burning plastic.
Now the headlights do not work at all, and still the smoke when it's been on for a little while.
The parking lights and everything else seem to work just fine, and a sight inspection under the hood reveals no broken or worn wires showing.
Could it be something as simple as the headlight switch?
Jul 5, 2007 at 4:20 AM
MERLIN2021
  • 17,250 POSTS
You did't say what kind of vehicle it is year, make, model please....
Jul 5, 2007 at 7:09 AM
PORCELINA68
It is a 1996 Jeep Cherokee, 4 cyl.
I checked the lights at lunchtime today, and the didn't come on when I pulled the switch, until after I turned on the high beams. Then the low beams worked, too. Unfortunately, I didn't have time to sit with them on to see if it started smoking again.
Jul 5, 2007 at 8:11 AM
MERLIN2021
  • 17,250 POSTS
94 is to old for any modules...so I would pull the connector off the switch and inspect it for any sign of melting or burning wires, if it looks OK change the switch.
Jul 6, 2007 at 12:15 AM
Suggested Repair
Disconnect the headlight switch connector and inspect it for melted or burned wires. If the connector looks OK, replace the headlight switch.
Conversation Summary
The owner of a 1996 Jeep Cherokee reported intermittent headlights, smoke and a burning plastic smell from the dash above the switch, then total headlight failure while parking lights still worked. The expert advised inspecting the switch connector for melting or burned wires and replacing the switch if the connector looks OK.
